How To: Install 2005-09 Mustang Front Bumper Park Lights
Tyler@LMR
2005-09 MUSTANG PARK LIGHT INSTALLATION INSTRUCTIONS
Read along as Latemodel Restoration walks you through a step by step install of the direct replacement park lights on the 2005-09 Mustang.
REQUIRED TOOLS:
  • Flat-Head Screwdriver
  • Phillips-Head Screwdriver
  • 10mm Socket
  • 3/4" Socket
  • Pliers
INSTALLATION INSTRUCTIONS:
  1. Remove the 6 plastic push pins from the radiator cover.
  2. Remove the radiator cover and set aside.
  3. Remove the 2 10mm bolts holding the bumper pillar in place.
  4. Pull the pillar up and to the front of the car to release the tabs.
  5. Remove the three phillips-head screws that hold the splash shield to the bumper.
  6. Remove the push pin holding the splash shield in place and pull the splash shield back.
  7. Remove the two bolts holding the bumper to the bumper bracket.
  8. Do the same for the other side.
  9. Pull down on the bumper to release it from the bracket.
  10. Once free, move the bumper forward and release the fog light and park light conenctions.
  11. Remove the bumper and set aside.
  12. Carefully squeeze the two retainers holding the park light in place and remove the park light.
  13. Twist the bulb retainers counter clockwise to release them from the housing.
  14. Remove the bulbs and replace with the new bulbs in the kit.
  15. Reinstall your bulb retainers into your new park lights.
  16. Slide your new park light into the front notch in the bumper and snap the park light onto the retainers.
  17. Reinstall your bumper making sure to connect your harnesses to the bulb assemblies.
Stay tuned-in to Latemodelrestoation.com for all of your 2005-09 Mustang parts and videos!
speedfreak1000
2 sided tape expert
Springfield KY
sweet.
next weeks lesson is how to install a short throw shifter.
like the old song goes
cha cha cha cha changes
time to face the change
weather man
Persistence Is A Bitch
MN
