Dubstep Shep
WUB WUB VROOM VROOM
Same length, even though there are the relo brackets? (Install won't be for at least another 2 weeks or so, so I'm not rushing it)
Correct. Here are the instructions for the poly bushing LCAs
Awesome!Correct. Here are the instructions for the poly bushing LCAs
Hahaha just LCAs is like a thirty minute affair.Awesome!
I already downloaded that from their website. The only thing I'm missing now is a good weekend. Haha!
Depends on what was intended and whether the offset is toward the outside (tire side) or toward the inside. There is a slight effect on axle roll steer and another on what happens to the thrust angle as the axle is adjusted laterally (typically for "centering" purposes).![]()
Does that look right?
Yea, I know there aren't any excuses, but it's been like 20-40 degrees outside [emoji14] and wet!Hahaha just LCAs is like a thirty minute affair.
But yea, some of the stuff isn't on the website, I've had to email Bruce on a few occasions for stuff.
Also just found out from Bruce thay S197 hubs and brakes will work on the SLA kit along with electronic steering. Awe yis.
Ahh...Depends on what was intended and whether the offset is toward the outside (tire side) or toward the inside. There is a slight effect on axle roll steer and another on what happens to the thrust angle as the axle is adjusted laterally (typically for "centering" purposes).
Awesome! thanks for the reassurance!Seems right. Here's a Griggs car with the same arms showing the orientation of them. You should probably consider getting them welded in also.
Thanks. Not a huge surprise, but it's better to see it than guess at it.Here's a Griggs car with the same arms showing the orientation of them.
Awesome! I've got a pretty good idea of what it should look like. I'm shooting for installing em 2 weeks from now
I've got a friend that has a torque arm on his new edge.Yeh it does hang rather low. I was a little worried about it for a while, VIR has a few turns that i straddle the apex's and no contact there so far.
