That's it? LOL...Shot a new exhaust video
1- Where is the nice pull?
2- Tell you video person not to stand a 1/4 mile away.
Sounds good though!
I don't hear anything really odd?
^^^ resonator delete metallic rasp
Every time I see pictures of this, I almost pull the trigger. I LOVE rear seat deletes! I just want to have 2 10lbs bottles mounted where the seat used to be. One day...Installed Bullitt grille along with Watson Racing roll-bar and rear seat delete..
Sounds plain as day to me. Like a baby rattle being shaken. Almost sounds like an exhaust leak except there is no leak. My wife can't hear it either however I've had several other people in the car with me and they have no issues and noticed it right away.I don't hear anything really odd?
I listened to that about 10 times at full volume, even had a coworker listen. I can't hear it, odd.Sounds plain as day to me. Like a baby rattle being shaken. Almost sounds like an exhaust leak except there is no leak. My wife can't hear it either however I've had several other people in the car with me and they have no issues and noticed it right away.
Never noticed anything like that in any of my buddies cars with ORP's either. You sure it's not something else?
Ok, I tried it with bigger speakers this time. I hear it a little, it sounds to me like o2 sensor collar rattle. My LS1 Camaro made the same kinda noise, ended up being loose collars on the o2 sensors. Crimped them up, gone. You look into that?Look at the comment on that video. I also had other people who can hear it. Especially around the 5 sec mark in the vid its easy to hear. Its just normal tinny rasp you get with that setup. There is no leak in the system.
Some people don't have the sensitivity to pick up on it. My wifes the same way. Drives me crazy though lol
It was the actual collars on the sensors.I suppose anything is possible. I never noticed any loose fitting connections when I put those sensors in and tightened them down to begin with. It immediately started doing this after the o/r h went on. If the resonators don't fix the issue then I'll look it over when I change the oil in April and see. The collar you speak of is the actual threaded part welded into the pipe? Or is it part of the sensor itself?
In addition to the comment on the video from someone who states they have the exact same issue I see other complaints that are similar.
http://www.allfordmustangs.com/foru...295573-off-road-h-pipe-sound-leak-normal.html
http://www.allfordmustangs.com/forums/5146026-post23.html
http://www.svtperformance.com/forum...ng-hissing&p=14163710&viewfull=1#post14163710
Why did you get rid of it?
Also how many miles you have on your car now? Trying to see who has more miles me or you, bc like you I am hard parked...
How many do you have?He got tired of dusting it cause thats all it catches!
I say 000212.7
Unfortunately the stainless was $120 more and you ended up with two clamps being used instead of one. If it is the aluminized steel that is the cause of that metallic tick/rattle that is disappointing but it isn't something lethal warns you about therefore I had little way of avoiding the issue.Another thing may be the cheap steel Lethal uses, the ones I've heard are stainless. Wonder if that could change the sound? I really do not see how resonators will cure the sound, since the sound that you are describing that bothers you is coming from upstream in the mid pipe section…
Damn!!! Haha. I just turned 1300 on the last nice weather day we had before the last snow we had here.273 miles now!How many do you have?
Close!!!![emoji38][emoji38]
