EB Goes 11.777 @ 117mph
fdjizm
Drag Queen
hmmm.. figured a little better than that with a new turbo + gutted but good time nonetheless.
Department Of Boost
Alpha Geek
Did you watch the video? Stock converter on the foot brake. 1st day it was ever run. That sucker will be quite a bit faster with a converter and trans brake.
ford20
White Plains,NY
Sure doesn't look gutted to me although I guess our definitions of gutted are a wee bit different.
+1 plus once they get the suspension dialed in I'm sure those times will drop a little bit more.
Department Of Boost
Alpha Geek
It scaled at 3040# so it's pretty light!!!
Department Of Boost
Alpha Geek
NEEDS A CONVERTER BAD. Fuel is probably close to maxed.
IDK about the fuel. I think the pump is the same as on the EB F150's. I make 400/520 to the wheels and it's safe. And that is through a truck trans, transfer case, big rear end and 33's.
And if you put a big lift pump in you can make more power.
fdjizm
Drag Queen
Just going by the article... not the pictures.
Watson's then removed the heater box, AC, all the sound deadener, airbags, and anything and everything else this car didn't need to go down the 1320. Once gutted Watson went to work installing their custom parts.
:headscratch:
In the trunk, a Cobra Jet fuel Cell was added along with an Aeromotive fuel pump.
Department Of Boost
Alpha Geek
Aeromotive doesn't have a fuel pump that will support DI. It is being used as a lift pump for the mechanical DI fuel pump.
Stock there is a XXXlph electric pump in the tank to feed the mechanical pump which is driven off the camshaft.:thumb2:
s8v4o
Can I shoot the engineer that but the air filter right behind the radiator! WTF?
