Car Studders/Falls on Face when attempting to build boost
PaRaDoX
So a quick background/Mod list
p1sc procharger at 12.5 psi
meth/water injection
full exhaust (catless)
On friday I went to launch the car, the car launched no issues, got about 3/4 of the way through 1st gear and then i heard a massive backfire. The car threw the wrench symbol and absolutely would not move. The car then would crank but not fire. Found out an intercooler pipe had popped off and then the engine became flooded.
The car ran fine for another 50 miles but now the car can't build boost without studdering.... feeling just off and I really don't think if I pushed it that it would build past 5 psi without breaking up real bad.
Shortly after this started happening my Fan stopped working completely. Not sure why. I waited for the car to cool off completely. Went to start her up and the car would crank but would not completely start without giving it some gas. Once she was started it idled fine, i rev'd it up a bit and still heard it break up when trying to build boost. (i was trying to rule out the possibility of the fan not working/correlating with the power issue via cutting back timing or something along those lines)
Before I pull out the spark plugs to see if they are fouled, anyone have an idea as to what could be causing this that would have an affect on my fan as well? (the fan is brand new as of November 2014)
Note: I feel like this was disorganized and not clearly typed out. If something doesn't make sense or you want some clarification please point it out so I can elaborate.
have you checked all the intake and vacuum fittings to be sure they are all tight and seated properly?
Mitchell205
oakland california
Going with spark plugs and checking your wiring around where the coupler let go in addition to stkjock
thump_rrr
Montreal Qc,
Is the meth still functioning?
If not that would be a reason for it breaking up if it was tuned for meth.
PaRaDoX
I haven't been able to really take a look at anything yet. First glance i saw nothing loose.
The meth only kicks in after 8 psi and i can barely go past 0 let alone make it to 8.
thump_rrr
Montreal Qc,
Another possibility is that the meth is injecting when it shouldn't.
PaRaDoX
Ding ding ding. Thumpr is our winner. The connections for the meth came off somehow. Hooked em back up and the car runs good as new.
