These are actually tire coatings not dressings
[/QUOTE]I am a fan of CarPro PERL Diluted 1:1. I am also going to try the Turtle wax coating in bottle not spray.
Same here. Even worse, I live off a dirt road. So even if I let the tire stuff dry for a couple of days, the dust still clings to it and looks like crap. So I'm better off not using it, but I don't like the dull tire either.Any consensus on tire dressings that work? I find all the brands I use turn the tire dull and brown after awhile. Are there any products that work as advertised?
Thanks.
Unless there's some that truly dries and doesn't attract dirt.
Thanx!TufShine will be your friend, in fact you take a white glove to after its dry - the gloves will still be white!
Thanx!
Think of it as a clear coat for tires. Durability is 3+ months. Clean tires with reg soap and water then recoat if you want more shine.
Why have I not heard of this?!
Thanks!
Tufshine actually isn't super expensive, I used it previously on my old ride and am currently using PERL 1:1. Might go back to tufshine and do a comparison vs PERL.
