Mattamus
- Joined
- Jan 13, 2011
- Posts
- 188
- Reaction score
- 0
I installed front and rear roush sway bars.
So, this is what most of the wiring out of a new mustang looks like on the floor. (All except the engine and trans/battery harnesses which already came out):
After almost 5 years of ownership...sold it. Bye S197forum...its been fun!
Washed it! It's nice to be outside without a jacket! Needs clay, polish, and wax now.
If you want, I know who does all the wiring for Ford Racing well at least the Boss 302 R's and can get you their info. They would open everything up, pull out what you don't need, and put in new military spec connectors.
That would make things nice and easy. I'm getting rid of the junction boxes under the hood and in the kick panel as well though. Going to rewire for just head/tail lights, turn signal, power windows/locks. Then going to add in my stuff like the holley, boost control, tbrake, 2step, etc to it.
Yes: Here's a copy of the e-mail I got from Dave Decker @ PRS:
PRS developed this upgraded version harnesses package for the 302R working in conjunction with Ford Racing to address and eliminate the vibration issues and terminal / connector breakage problems with these sensors.
We add military-spec grade wiring pigtails to the following sensors; (4) cam actuators, (4) cam positions, (1) crank position, and epoxy pot them at the sensor wire exit. The wiring is covered in high temp Raychem DR-25 shrink cover and terminated with Deutsch DTM series connectors. We also change out the factory connectors for these sensors on the engine harness with the Deutsch connector. All connectors receive military-spec gold plated terminals. We would need:
- (4) Cam actuators
- (4) Cam position sensors (2 gray / 2 black)
- Crank position sensor
- Engine Harness
On the Stage 2 Race versions we eliminate several connections that are not required, for example: purge canister, radio noise capacitor, oil pan sensor leads, etc. Stage 1 Street car versions retain all the connections.
Components are priced as follows:
- Sensors are $85 each (x9) - $765
- Harness modification is:
o Stage 1 - $300
o Stage 2 - $375
Total Stage 1 = $1065
Total Stage 2 = $1140
Our current turnaround time is 2 to 3 weeks.
