roflmao
My office got a kick out of that!
We were thinking about making an infinitely adjustable PHR with a large threaded rod.
If it adjusts from a PHB to a LCA you know my details for the preorder.
roflmao
Kelly,
Those are definitely really nice rear components and will more than likely take you up on them.
How do your handling springs compare to the MM r&t springs, and have you had issues running them with MM camber plates. Reason I ask is I'm having issues with Steeda sports and MM plates and am going to go a different direction with springs.
Kelly
Yeah the issue I'm having isn't with the camber plates, its actually with the springs. the factory spring perches used with the camber plates when inserted into the top coil of the spring causes the camber plates to sit at roughly 20 degree angle relative to the strut shaft installed.
I've spent sometime talking to MM and we've come to the conclusion that the springs I have are wound incorrectly causing the issue, and is the reason for my interest in the MM r&t box components. Figured I couldn't go wrong with matching components in regards to assembly.
I appreciate all the advise I've received from you, as well as others thus far. I'm sure we'll be doing some business in the near future.
Mark
Yeah not really thrilled with the factory bearing/spring perch myself. Seems like the weak link in the front suspension, I just cant justify coilovers. Just want my car to be a extremely good handling street car, which validates csamsh point against spherical bearings for daily driven suspension components. I'm on board with Kelly's advise of using bearing/bushing components to maintain streetability and will take that approach. Thank you both for your input.
Mark
csamsh
I pulled the trigger on MM plates, there sitting on the work bench. would have preferred the Vorshlag plates but lead time was unknown when I wanted to make the purchase. If I'm not mistaken both sets use the factory bearing/spring perch?
Can you post pictures? I know exactly what you are talking about. Our springs are wound just a tad different than oem, but it's very comparable.
I can share pics when I get back in tomorrow of our springs and oem springs, with gt500 mounts sitting on each.
