ZmanM3
The Evil One
Actually 1st gear is better with the hand barke on. Thats how I changed my UDPs.
I think I had mine in 1st gear too.
Actually the highest gear you have is the best. First gear multiples torque to the rear wheels, by doing that you can actually move the car by trying to break the crank bolt loose. The highest gear reduces the amount of torque being transferred to the rear wheels.Actually 1st gear is better with the hand barke on. Thats how I changed my UDPs.
gey a painters funnel with a screen, works great
Yes but this way you can drop the K-Member enough to pull the pan.Thanks peter. I have the doc but i cannot remove the oil pan without lifting or pulling the engine as it is not the stock pan, but a moroso 7qt pan. I was gonig to pull the cam cover first, then check the cam caps, then pull the timing cover and check the oil pump
That's a good idea thanks. Is the screen a fine mesh? I've gotta be able to catch metal particles
Do you think maybe a hunk of silicone was at the bottom of the pan.
it's only 8 bolts holding the K member to the chassis + 2 bolts holding the engine to the K member. Rent or borrow an engine bar or engine hoist for a couple of days.
wow ron, I've got my fingers crossed for ya that you dodged a bullet. Sure looks like it so far. I want to see the oil pump...![]()
