it's not optimal fitment, however, it works.
It fits because M&H run narrow. If you look at their website you aren't supposed to run that tire on a 10" rim. Not even close. Real world says otherwise.10" rim![]()
Similarly their 275/45/18 also runs narrow. I have it on a 9.5" rim and it doesn't provide much protection against rash at all. Clearly runs narrow. And yet they want that tire on a 10" rim.
I was going to go with the M&H 325/40 like you did but a 9.5" rim might be pushing it.
So these showed up last week.
I still have some tread left on the current drag radials so they will sit for a while.
Never stopped to think that the taller tire would throw off the LCA angle. Guess if I still have major traction issues on the street I will have to get brackets. Was hoping to avoid them since the axle isn't welded or braced and brackets make a twisted tube more likely.
Not a lot of clearance. As long as it doesn't rub on the edge of the wheel well...u should be ok. But u only have 1/4" of wiggle room.
Tread wear rating of zero.... how long are they gonna last ?
Ok, are they R rated for speed ? That's only 106 mph per tire rack.
http://blog.tirerack.com/blog/make-driving-fun/understanding-speed-rating
Nitto drag radials are V rated... max speed of 149 mph.
I wonder how it will handle on a road course or autoX or the street....with those huge sidewalls ?
The story I got with drag racing is you don't want it to squat, you want it to pivot. I think the idea is not to transfer the weight into compressing the rear springs. Looking at the "tread".... you may want to be cautious in the wet /rain.
Speedboosted - I think your cars a stick? If so the hoosiers are actually better as they have a softer sidewall and wrinkle like a bias ply tire its easier on the driveline and more consistent on differently prepared tracks
I swear sometimes I read your posts and wonder if your joking or just retarded
ET streets have no speed rating Mickey Thompson recommends 85mph but its a drag tire.... people doing 140+ passes its a different scenario then a long wear consumer tire meant to do hours on the highway
As for basically all the other comments its a drag tire it has a 000 wear rating, no sidewall, its meant to do one thing good.. hook
He uses it 99.99% on the street as a DD....with some use in autoX + the strip. He's near Seattle, and they get a lot of rain at times. With his power level + 4:10 gears, he doesn't have much choice for traction as a DD. For DD /street use, something like Nitto invo's etc, in a 315 on 11.5" rims might have been a better option.
So I got my tires mounted today!! Holy crap are these tires HUGE!!!
Why does my suspension seem lower than yours Retfr8flyr?? Check out how much little clearance I have:
I don't have a finger worth of clearance/gap between the edge of the fender and top of the tire; the top of the tire is actually in the fender (1/4 panel).
I am worried about the clearance. I do not know how much the rear suspension squats during launch.
Here they are next to my 275/40/18 daily street tires:
Not sure, haven't been counting. I have used them for two summers with multiple drag racing events. I only get to use them for a short time in the dry summer months. They still have quite a bit of rubber left on them...but I want them gone as they are too short of a profile tire.
