ZmanM3
The Evil One
Biggest pictures ever. Want a billboard to post those on?
Clutch change (Exedy Stage 2), which was hell to do, but it was definitely time at 91K miles.
Pulled the Ford Racing gauge pod out, again, and put the screw in the visor that I lost last time. Took a half hour to find the correct screw at Lowes.
Couldn't get the screws in tight with it mounted so had to undo it from the dash. The 2 screws holding it in place are a bitch to get to, and then I couldn't remember what size they were so almost an hour trying to get to them (after getting one to come out discovered the socket I was using was just a little off so the second one was easier). Since it was open I checked the oil pressure gauge to make sure nothing was loose there causing it to read funny (like 100 psi at idle after the car sits for a bit) - I'm starting to think that something might be screwed up with the gauge itself. And checked the wiring for the light on my boost/vacuum - discovered that the power wire had come loose so now that lights up once again! And on the plus side the pod is mounted much more secure than last time and doesn't shake; I think that I didn't get it all the way on the back post last time.
Waiting on the new waste gate from Hellion. I sure hope that is the problem with the overboosting. Everything is connected properly, but for some reason the 5 lb spring hits 10 and climbs fast. When I opened the waste gate to check it for Hellion couldn't budge it at all. Seemed to be jammed up so John Urist is sending a new waste gate.
i went cheap - stop 67k struts and mounts, but swapped my BMR springs in. god does it look good, but now its begging for 18 or 19 inch wheels.
oh, and the mirror i ordered.....
[/IMG]![]()
blocker rings?
Installed a roll bar.
I was hoping folks would overlook thatAnd a mirror [emoji14]oke:
