s197 parts compatibility
Corpo
I
Red Deer, AB
Just wondering if there is a list some where on what parts work between 05-09 to 10-14. Someone I know with a 14 is interested in some of my old parts off my 05. Tokico d-spec shocks/struts, eibach pro-kit springs, and j&m camber plates.
I am suspecting they won't work for him, but I would like to be 100% sure.
Thanks.
Whiskey11
SCCA Autoscrosser #23 STU
Thanks.
Everything swaps over suspension wise. The only major differences are the way the front struts are cut and the length of the rear UCA and the UCA mount. The 05-10's is 1" shorter than 11-14 and the mount is different. The front strut being cut differently isn't an issue so long as he uses the correct strut mounts. IE: If you have 05-10 struts for your 11-14, you need 05-10 strut mounts. If you have 11-14 struts for your 05-10, you need 11-14 strut mounts. There is a slight additional drop by mounting 05-10 struts on an 11-14 of like a quarter inch IIRC.
csamsh
OKC
I think the front A Arm mounts are different as well?
Whiskey11
You can mount an 05-10 arm on the 11+ K-member. Biggest different is balljoint diameter. Forgot that one. Thanks!
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
'11+ GTs have larger front brake rotors and correspondingly different calipers. They swap directly onto earlier models for a cheap brake upgrade.
All '11+ V6 models have the 8.8" rear with positraction.
SlowJim
56 miles south of Mid-Ohio
I can vouch for this. If you have camber plates such as Maximum Motorsports they provide spacers which will allow you to use 05-10 struts on an 11-14 car with no additional parts.
