rojizostang
i love my cams
several of us have talked about how after installing hot rod cams the tranny will rattle...this is in neutral. with the clutch depressed, it stops. so i was reading in the dizzels thread about someone saying that his throw out bearing rattles around because of a hydraulic/bleeding issue. now i've never had the clutch, tranny, or any of the driveline out of the car except for the drive shaft and gears, so i don't imagine it would be an "incorrect bleeding" issue.
it can be fairly noticeable...i don't think it actually hurts anything..but what could be the cause/cure?
also, fwiw, i've never owned a mustang that didn't have at least a little throw out bearing noise...
