Car wont start/Gas smell under the hood
702GT
S197 Fanatic
Las Vegas
If you were under the car, look near the A/C compressor. It sticks right out of the timing cover next to the compressor.
Aesthetics28
So..... I feel like a complete idiot.
I was checking underneath my car to see how my cps is and found something quite interesting
Uptop when I was checking for leaks you couldn't see much but down below the orange color gave it away.. Thanks guys for helping out as much as possible I really appreciate.
It's usually the first thing I like to do is check for leaks and vacuum openings. I shouldve known the engine wasn't getting air cause of a big ass leak lol
702GT
S197 Fanatic
Las Vegas
Looks like a normal open atmosphere bypass to me. Lets keep tearing it apart!
702GT
S197 Fanatic
Las Vegas
It does look like some T-bolt clamps could be in order when you do your next upgrade shopping list :)
Lol, at least it's a simple easy fix.
05mustang_TT_charged
Because Race Car!!
LSU Country
If it was me I would replace the crank position sensor. They are cheap and IIRC, the tack should move while cranking the motor over. Not just after it starts.
Engine would never start with a failed Crank sensor. When cranking the computer looks at the Cam sensor for TDC and then starts counting teeth on Crank sensor. If it is bad computer will not be able to locate TDC to fire injectors and coils. Once car is running it only looks at Cam sensor for VCT control and fire injectors and coils off Crank sensor.
Aesthetics28
Thanks for the heads up.. But wasn't starting at all which is why I thought it was that I guess with maf unplugged to it wouldn't start
Sent from my SM-N900V using Tapatalk
