Boy, installing this DoB supercharger kit has been a real pain in the ass so far and it continues to grow in size lol
Today I went to install the 8-rib pully and turns out it wasn't even close to lining up with my alternator pully. IDK if the 2.3 TVS I bought is some special version that is molded differently or what, but I had to machine an 1/8th inch off of the overall length of the hub, rechamfer the hub, take an 1/8th off the inside of the pully and open the face of the pully more so the s/c shaft could poke through. After heating up the hub I placed it on the s/c shaft and it seems good to go this way.
Then it turns out the 130'' serp. belt that everyone uses in the kit is nowhere near long enough for my setup. I have no idea wtf but this shits getting old.. I'll be off to the autoparts store to see if I can track down a similar belt that is 2 inches longer.
Like every part I'm putting on here, except for the manifold itself, is used and this is all going to end up costing me nearly as much as a vmp 2.3 setup that would have probably bolted together more. IDK if I'm even saving any money anymore. guess piecing ur own kit together isnt all its cracked up to be boys.
So far i've had to:
Build/machine my own custom puller to get the used TVS pully off
re-machine the pully and hub assembly
fix the ass damage my manifold got during shipping (thanks ups)
drill/tap/plumb a new hose connection on my tvs elbow since it came missing one of the 90degree tubes
drill/tap the block off part to block off the evap or whatever holes on the TVS
take the s/c off of the manifold to remove a bolt in the t-stat housing for clearance
re-buy a ton of fuel line/vac lines as the ones I got off of amazon months ago didn't seem sturdy enough
broke off TWO cylinder temp sensors in the manifold. either the torque spec is super wrong in the kit instructions or the sensor I had in my car was different.
bonuses with/of the 8 rib pully swap
drive all over gods creation to get a special socket spline tool to take off the alternator pully
spend hours looking for the special 8-rib decoupler style pully and eventually giving up
replace two bearings inside idler pullys with wider bearings for proper alignment
rent and take back 3-4 different shitty pullers from local autoparts stores until I got the correct ones to remove all the godforsaken 6rib pullys
someone remind me why im going thru all this insanity?
TLDR: don't screw with the kit. if you decide to get all custom and upgrade blowers, swap to 8 rib pullys, ur in for a ride
So far i've had to:
