Palanza's 06 GT Teksid Build lets goo
palanza7
How lean?
lito said "Car is very lean but is keeping a very high idle, sure there are no leaks?" so im going to recheck for any vac leaks, i didnt actually feel around. i did overtighten the manifold in the beginning a bit due to mis-reading my torque wrench, but I loosened it up, lifted it up and then retorqued it correctly after that so hopefully its not there lol
Department Of Boost
Alpha Geek
Have you tried checking for leaks with either or carb cleaner?
palanza7
can't say ive ever done that before but that sounds like a pretty nice idea. i'll give a little spray around the manifold and pray to god it isnt one of the intake seals.
Wes06
didnt miss one of the caps or something for the blower did ya?
Department Of Boost
Alpha Geek
Works like a charm.
And if you can't keep the car running long enough to test it unplug the MAF sensor. It will trip the ECU into limp home mode and it will idle.
palanza7
So I found the vac leak lol.. honestly I'm not going to even post where it was leaking from its that embarrassing haha
by the way, there are some extra washers and bolts included in the kit right? because I do have a handful of left over hardware that I never used.. LOL hopefully nothing's missing. Going to have to do a once over again to make sure I didn't miss anything.
skwerl
tree hugger
central Florida
Go back through all your vacuum ports on the intake from the MAF to the intake ports. Trace every one out to see if there's something leaking or disconnected. Dunno about that TVS but my Roush M90 had a vacuum line running from the bottom of the intake manifold back to the blower elbow, designed to keep oil from puddling in the bottom of the intake.
So which line was it? You can tell us, we won't laugh. (snicker)
palanza7
It wasn't a line..................................................... lol
So I somehow missed putting in one of the bolts that hold the supercharger to the manifold. It was by itself all the way in the back. I have no idea how I totally wiffed on that. I took the belt off, loosened up all the bolts then stuck the missing one in and torqued them back down to spec. Idles like stock now lmao
Department Of Boost
Alpha Geek
Those 8mm holes will move some air!:roflsquared:
palanza7
Right. Well I've never even heard a supercharger in person really so I didn't immediately distinguish that leak sound apart from the spin of the supercharger itself. Now to button up the bumper cover and a few other odds and ends.
pics06gtstang
SWFL n ft myers
almost there james .
and that first time ya hear that boost makes ya smile soooo big !
wont be long now , as long as no snow you might get a ride soon !
Good work buddy .
Department Of Boost
Alpha Geek
There is no way you could have heard that. Blown motors are a bitch to diagnose vacuum leaks on.
The first time you go WOT and it turns the tires to goo you'll forget about the entire install.:clap:
palanza7
Good work buddy .
Yeah no joke, its supposed to warm up here on WED so that'll be nice.
Haha I'm pretty pumped. At the moment its so cold I decided to hold off on putting the cover back on until tomorrow. Crazy, supposed to be 7 degrees tonight and 50 on wed lol
palanza7
So am I going to destroy my engine pushing 16psi andrunning stock cats?
BruceH
BBB Big Bore Boss 322
I've always run stock cats with my forced induction setups. Never had an issue. I did have the cat protection come on when I was running low spark advance with my first FI tune, be aware that making a lower hp tune by keeping the ignition timing low will make the exhaust very hot.
I keep the cat, exhaust gas, and exhaust valve protection turned on in the tune. That might be part of why I've never had a cat related issue.
I figure if it works with a GT500 then why wouldn't it work with my setup provided I don't let the cats get hot and melt.
Others have had different experiences with forced induction and cats. YMMV.
palanza7
Good info Bruce. Do any of you guys know anyone who swaps cats in to pass inspection? H pipe in and out wasn't too bad when I put the wideband in
