pics06gtstang
I'm starting to reassemble everything and found what I think is another small issue, this time with the driver's side phaser. The three roll pins are slightly loose, just enough that I can wiggle the trigger wheel.
"Small issue" , never .
if them phasers are loose in any way i would replace them w/ OEM , and if it was
me i would lock them out also while i was in there .
but loose is not good at all IMO .
as far as the tensioner goes the original have shit gaskets and they leak oil
@ that point , the new design has an o ring type gasket . i would invest in new tensioners .
