Deal of the day for 05-14 owners
Norm Peterson
corner barstool sitter
RIP - You will be missed
The PHB brace isn't part of the main chassis, which you still wouldn't be touching. But depending on its strength, the loads it can feed into the chassis can increase. I'm looking at the repair expense increasing with a stronger brace without getting a measurable performance benefit from it the rest of the time. I doubt that even the exhaust routing benefit really amounts to a whole lot in any car that isn't ripped apart for a cage anyway
If I was to go under my car today and find the OE brace starting to crack, I might still get this or something like it (if I didn't just weld up and reinforce the OE brace). But it would be a choice taken with a clearer understanding of the plusses and minuses than the average e-Bay shopper goes into such purchases with.
Phil1098
Central Illinois
Now I've got something for you guys to think about. Let's say you accidentally put the right rear tire & wheel mostly sideways into a curb - there seems to be enough video evidence lately demonstrating that it's certainly possible. Would you rather have more damage passed on to the car's main structure because the brace DIDN'T buckle?
With all due respect Norm, this argument doesn't wash. Depending on direction of impact (a left side impact or a right side impact) the brace is either in compression or tension. In tension I doubt the stock one would stretch much. Not only that, if you stuffed one of these cars into something with sufficient force that it bends and twists the chassis, the car is totaled anyway. The body shop won't call and say "thank God that support brace bent, your car is fine." Won't happen because if the brace is all folded up, the rest of the chassis is junk. I looked at the stock brace, there aren't any relief areas like crumple zone dimples for controlled collapse. It's just a stamped steel brace that was done at a price point.
Phil1098
Central Illinois
You are completely contradicting yourself here. The first sentence says it isn't part of the main chassis and then the second says it loads the chassis.
If the PHB brace isn't part of the main chassis, what exactly does it mount to? When I was under my car it sure as the world attached to the chassis. Ford doesn't mount and pivot the panhard bar off the chassis? Yes they do.
Phil1098
Central Illinois
So if it was found on the Steeda, Whiteline, or BMR site then the potential buyer wouldn't be quite as stupid? No reason to be condescending just because Granatelli decided to market them on eBay.
Norm Peterson
On a right side impact, if it fails it will fail in compressive buckling. The right side "pedestal" that it and the PHB attach to will bend over and more than likely distort the right side frame rail locally. The left side frame structure won't have as much damage, maybe none at all.
All bets are off on a left side curb strike unless the PHB itself buckles early enough. In that case, you'd be hoping that the PHB could provide a "structural fuse" function.
Bolted-on braces are supplemental structure, not main chassis structure. This one isn't there for anything other than to distribute the PHB loading to the driver side of the car, and wouldn't be there at all if the S197 had used a different type of rear suspension.
The risks are still the same, and I would have still shot down the "OE is flimsy" argument with the same words - which is my main gripe here.
I have advised against bothering with the brace for the same reasons before, several times, on several forums, without regard for whose brace might have been under discussion or how it was available. That it was Granatelli's brace here, with e-Bay availability rather than direct, was strictly incidental and had nothing to do with anything I posted. I'm biting my tongue a bit specifically because it's Granatelli who is involved, but that's all I'm going to say about that.
You can always propose a crash situation beyond whatever the existing structure and supplemental suspension bracing can cope with. But until I find that the OE brace is inadequate (and I commonly load my car's PHB brace up higher than most S197 owners ever will) I will choose to keep whatever "window" exists between PHB brace buckling and more consequential serious damage on the left side.
Now . . . you can choose either to insult me with words like 'condescending' or accept the possibility that I might have learned a thing or two about structural topics over the 40 years or so that I was either studying it for my BSCE or getting paid to do it.
Phil1098
Central Illinois
I have no reason to insult anyone, you're usually pretty level about most of these things. You also assume that no one else has any knowledge of how things work. Clearly you can't say that you in any way could be wrong, irrespective of how things are shown. I've worked with many Phd engineers over the years, some were brilliant, some couldn't see the real world. You and I have about the same year car, if the structural area that the panhard bar pivots from is hit so hard that it moves, the car is totaled.
weather man
Persistence Is A Bitch
MN
Norm, your argument might have some merit if a guy had EVER posted up that they installed this bar, or the countless other look a likes from the other vendors, and had an issue. On all the forums I am on, I have NEVER read such a post.
Norm Peterson
I know I've seen at least one thread (not necessarily on this site) involving a RR curb strike that ended up with the car's owner complaining about an uncentered rear axle after the repairs were supposedly completed. I forget the rest of the details, but the bottom line is that the curb-strike situation can occur and has occurred.
No, it doesn't happen very often, but with no performance benefit to be had by swapping one bolt-on brace out for a slightly different one it doesn't make a whole lot of sense to me to accept any increased risk. Thinking that losing the "flimsy" OE brace for something stronger or stiffer made it a performance mod is to kid yourself.
Maybe at some crazy cornering level like 2g or higher it suddenly becomes a different story, but I doubt I'll ever get there to find out.
Phil1098
Central Illinois
Norm, I like you, but you are living in a world of engineering with blinders on. I don't know how else to put this so here goes, Mustangs are cheap. I know on this site that is sacrilege, but it's true. You are viewing everything like this was as good as the Ford engineers could do, it wasn't. This is a car for the masses, so there are so many other considerations and compromises besides performance it's not even funny. Mass produced price point cars are like a camel. A camel is a horse designed by a committee, not good at any one thing, but meets all the criteria. If what you are saying about a brace being worthless then why does Ford add a strut tower brace, a K member brace, a cross chassis brace with a rear seat delete? I will almost guarantee you will agree that to optimize performance all suspension components need to move from a rigid repeatable location. You don't want the chassis winding up, you want the suspension to do the moving. Proof of this is all the braces Ford adds to the car. Back to the compromise, someone at Ford said there are Mustang owners that take people for a ride so they HAVE to have a rear seat, so it has one. The performance engineers say "well given the constraints we have (size, shape, weight) a cross chassis brace while taking out the seat is a good thing." They don't worry that one day a guy may wad his Mustang and the repair bill may change by $100, no they are trying to get a stiffer chassis. The aftermarket world has some constraints (price being primary, can't make a brace out of titanium and sell it for $500, no buyers) but they can focus more on a more narrow scope. Ask yourself why does Steeda, Whiteline, and BMR, to name a few, offer these braces if they do absolutely nothing. The increased risk you mention is almost laughable because the brace that is there will still transfer load on impact and if the pivot side mount moves it will also move the drivers side, anyway you look at it, the car would be totaled. So if we just don't drive the cars, our risk goes to nil, but that wouldn't be very much fun.
pass1over
I like it LOW
Trenton, FL
all kinds of companies offer and sell worthless items. Why? Because people buy them. This isn't really a good argument as to why an aftermarket PHB brace is needed or more effective than the 'flimsy' stock piece
Norm Peterson
What's wrong with GMS?
Before this site's time, and since I really don't care to see that shitstorm continued over here that's all I'm going to say about it either publicly or privately.
Phil - I know if I was ever asked to design a brace like this one that I'd have detailed the chassis end a little differently. Not sure how, but differently nonetheless. And no, nothing I might have heard before about my reply above to Stangiac was of any influence in what I've posted here now. Not at all.
5tangiac.0
Houston, TX
Installed mine today. Out of the box it's a decent piece. Only beef was mine had something left inside of it that moved back and forth. Probably a piece welding wire. Hopefully it doesn't make noise while on the car but I doubt I'll hear it with the roush ab and Offroad h.
The Install took around 25 minutes. No directions but it's pretty damn straight forward. Would have taken less if it fit loose like the stock one. It was a tight squeeze and took some love taps from the hammer.
Phil1098
Central Illinois
My stock brace fell out, but I had to loosen the panhard bolt and then the new one went in without any tapping at all.
5tangiac.0
Houston, TX
Ahh that may have helped. My stock one fell out also. The welds on the stock brace I noticed are only on one side as well.
JUSTA3V
Moar Throttle!
Queen Creek AZ
Advice. White mark the adjustable nuts. So you can tell easily if shit is loosing off on you.
Rapture
I saw this and spent the whopping $10 for it. I probably will never feel the difference, but the stamped brace is a joke and for $10, I can't see why not.
http://www.ebay.com/itm/2005-2014-M...ash=item43e5eea1fc:g:tjUAAOSwZVhWTlGT&vxp=mtr
and that is from their own outlet..........here is the same part on their website
http://granatellimotorsports.com/products/2005_2014_Ford_Mustang_Panhard_Rod_Brace-40-27.html
Now not many would spend $131, but $10????? Come on.
BTW, it's not a typo and I have a tracking number already.
Does it come in red
