I believe VMP has tried several different configs, with varying results.
Mine goes.... IC -degas - pump - HE...back to IC. Pump is located aprx midway between output (bottom) of de-gas and bottom of HE.
Coolant enters the bottom right hand corner of the HE..and exits the top left corner of the HE.
But I only have a Bosch pump, aprx 4 gpm.
Water doesn't compress.Compression of the medium
If you run any of the fan shroud located degas tanks their outlets are almost straight above a pump mounted on the DS just to the outside of the frame rail. This is how I packaged my stuff.
FWIW - The pumping process induces heat into your medium regardless of the medium type or closed loop process. Compression of the medium must occur for a differential pressure to be present which causes flow in a closed loop system. The byproduct of this work as with any work is heat. Therefore heat will be induced into an already cooled medium just prior to it entering the I.C. The efficiency of the H.E. is now compromised. In theory the best place for a pump is between the return tank and the H.E. source. This allows the H.E. not only to remove the heat from the return medium but also remove heat induced from the pumping process. The triple pass I received placed the HE pump down low on the drivers side. The feed from there to the bottom of the H.E. is only about 8-16 inches as I recall. VMP relocated the pump to take it out of the airflow path of the both the HE and the radiator. You could reference their location and bracket they send with the package which may be of assistance to your build. As for driver's side tank, my Roush system came with a driver's side degas tank. It holds I believe about 1/2 gallon. The majority of the coolant (mixed it 60/40 water to coolant since I street drive it even in the winter) to optimize heat transfer over standard 50/50 mixes. That said the most efficiency would be running pure DI water in your system as long as you remember to not leave it in the vehicle in sub freezing temps. Coolant, aka antifreeze, aka glycol, aka dowtherm, aka dowfrost is only present to reduce freezing temps of the water. It otherwise served as an insulator. Hope you get it all ironed out.
I just helped a Formula Drift team out with their IAT and belt woes. The IC was modded from 5/8" to 1" fittings and the hoses went from 3/4" to 1". It went from 5gpm to 13gpm. IAT's came down from 220deg to 145deg.
You will see your goals met.
I don't know man.
This Intercooler is like 3 - 4 times smaller than your setups.
I am setting my expectations low.
What pump was VMP relocating? This EMP pump is all gangly and has quite specific mounting requirements.
I only run water and some water wetter in the IC circuit and drain it before storage, winterize with glycol water mix.
Last summer back to back 30%glycol70% water and water+ water wetter appeared to net me a couple degrees in AIT.
Once again every * counts with this setup.
With the Saleen unit it's pretty tight with the alternator spun around .
But I have time to move stuff around just to see what can go where.
So essentially the factory ford Gt500 system routes in that manner, degas at the rad shroud feeding a pump below which from what I can tell feeds the HE from the top.
Everything is a possibility, but I wanb to get the most possible out of the system. Fullboogie posted an older thread from tmcolegr where he was essentially running the same set up and overspinning the saleen way past it's peak efficiency.
Lito and I ended up dropping a few pulley sizes to drop blower speed and lower boost to create a drivable safe pump gas tune.
It still gets hotter than I want.
So every * counts here. I am hoping to drop 20*AIT going from the bosch pump, .50" saleen IC fittings, I had a AFCO dual pass as the only upgrade in the system prior to now.
So new EMP pump, IC machined for 1.25" hose, awaiting DOB HE and Degas to be complete.
But I do have a miriad of parts and shit I picked up. SO this big ass GT500 HE, looks like a single pass 3 row unit can be fitted for 1.25" hose.
I have a few different Degas tanks lying around.
Don't know if 20* is possible as the IC is soooo tiny.
But even 5* across the board and a quicker recovery time would make me happy.
So that's it, I need to know what is the most efficient routing.
