3VNightmare
Tremec Magnum XL transmission used for approximately 800 miles (street driven) in a 2010 GT. I originally purchased this new as a full kit from JPC. Below is an itemized list of what is included. Also, I will throw in a new 05-10 slave cylinder as shown in the picture below.
- Tremec Magnum XL 6 speed transmission (2.66-1.78-1.30-1.00 -.74-.50) /SFI bellhousing/block plate (I had to oblong the starter opening on block plate to ensure proper starter alignment)
- Transmission crossmember
- Aluminum driveshaft w/pinion adapter
- McLeod RXT dual disc clutch PN#6932-07(does NOT include pressure plate bolts)
- McLeod steel flywheel PN#463406 (6 bolt crankshaft) (does NOT include flywheel bolts)
Asking $3,300 (will not ship - located in Orange County, NY)
