Unhappy with new best
M
MattD
Guest
60' 1.79
330' 5.066
1/8 7.766 @ 90.295 mph
1/4 12.057 @ 113.772 mph
I was THAT close to 11's. Oh well, time for a taller tire I guess.
My nitrous was cutting off before I crossed the line due to the short tire and I have it set to cut off at 6300 rpm. I don't really feel comfortable spraying the car at any higher rpm than that.
I made a total of nine passes that night on the bottle, time were between 12.0's and 12.3's all night. It was hot and humid, so maybe with a little colder weather and better tires I can hit 11's.
ZmanM3
The Evil One
Jackson, NJ
That is still a really good time, good job! Now make sure you go out there on a cool less humid day and rip off an 11.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
I presume you were running 275/40-17s? If so, I agree about the tire height... you're pushing the rpm limit in 4th gear with 4.10s. What tires are you looking to switch to? The 325/45-17 M&H's?
M
MattD
Guest
I was kinda thinking that the 325 would be too wide for a 9" wheel. I'll definitely look into those now. Thanks!
don_w
San Diego, CA
The M&Hs are not a true 325... they are more like a 265 in width (tread width is only 10.3"). The M&H 275s have a tread width of 8.8".
M
MattD
Guest
If you were to keep these tires on the road for everyday use, how many miles do you think you would get out of them? I know I use to get around 15k miles on Nitto DR's on my f-bodies and around 3-4k on M/T's, but I don't have any experience with the M&H's.
don_w
San Diego, CA
Paul has been running the M&Hs on the street for a while now... he'll have a better idea than me. But, since I only use them for the street (no smokey burnouts at the track), I'm hoping to get maybe 12K miles out of them. I guess I'll see in about 8-10 months or so.
retfr8flyr
The Old One
Providence Forge, VA
I will be running the M&H’s on the street also and the guys at M&H said to expect about 5 to 6000 miles from a set if you race every weekend and 10 to 12000 if you only run occasionally.
Earl
Buckman
Stockbridge, MI
Anytime I can hit a personal best and the car makes it home in one piece, I gotta say I am pretty happy!
Nice job, it's always good to know you can do better, gives more motivation to keep getting out there and chasing et's.
Charlie Sheen
Armed and Hammered
Infernum ubi sum
M&H posted this at another forum:
"If you only run at the track, you will get 1-2 year out of the drag radials, after 2-years replace them. If you run the drag radial everyday on the street, you will get 4-6000 miles out of them depending on how hard of a driver you are."
don_w
San Diego, CA
4K-6K sounds pretty low to me. I thought Paul said he got more than that, even when using them at the track, too. I'll be sure to let you know how long they last for me... 100% street duty and no burnouts.
