IMO don't start looking for new setup changes yet till your tuner gets a chance to change look at datalogs and make some changes.
This is a Centri setup, the CR I wouldn't get to hung up on as the limiting factor here. Centri's build boost and have a very linear curve like the one you have. If you had that CR and a direct displacement or turbo, I would be concerned with tip in detonation from IAT temps,timing and boost. Your graph curve looks low in power period, it starts to flatten around 6k, normally where it should be really producing all the way to at least 6800rpm even on stock springs and cams and they got out of it by 6500rpms?
I just think before you start bringing in the power band sooner it would be better to work out this current package. Must be a lot of peeps here who have that paxton with much larger hp graphs they could post up for comparison along with some parameter data they recorded.
Later you can add meth or E85,wastegate, O.D. Crank, Smaller Pulley to bring in the power sooner and bigger. Adding boost sooner but not increasing total boost is not going to work without a wastegate. If your just worried about Detonation throw the meth on to raise the octane or convert to E85. The E85 route removes the mechanical fail out of the equation but it seems lately that the gas stations are reducing content to E75 more and more, could be harder to find good E85 fuel in the future
