Since my last 93 octain dyno run car ran 729 rwhp dyno jet on nitto 285 18x10 wheels.
Since the above dyno
I made a exhaust change to pypes super system cat back with pypes bombs. I previously had flowmaster american thunder axleback using the stock over axle pipe
I also ran on dyno today with racestar 15X10 wheels with big 325/50r15 M/T Et street drag raidials.
These results are through a automatic trans with a single piece steel drive shaft large strange billet yokes biger 1350 u joints..No Aluminum.
Shell 93 octain only 13*total timing at peak.. Bob tweeked the tune to ritchen it up due to the exhaust & intake change made the afr a bit on the lean side he also pulled a touch of timing for added safty on pump gas and i was perfectly fine with it due to this beast is having no problem laying the power down even on 93 safe and conservative but still beast on pump.
Bob helped put together a great combo that WORKS with this car see attached dyno sheet only pulled to 6500 ish thers more in this thing straight C-16 race tune will be also tweeked for these changes next week i will post those results as well.
Paxton
novi 2200 8 rib is the blower on my combo.
Paxton
