blacllkllsi
- Joined
- Jan 24, 2009
- Posts
- 311
- Reaction score
- 0
I purchased the GT450 Stage 3 kit from Department of Boost about 2 months ago and am just getting around to installing it. I am running into a few problems on the manifold prep. One is the -an fittings provided feel like they are to large when trying to thread them, i.e. the inter cooler fitting on back of the manifold and the heater hose connection at the front of the manifold pictured below. I could not get the copper fitting to seat all the way and to get it that far took more effort than I think it needed. My concern is stripping the threads on the manifold since it is aluminum. Should it be this difficult to thread?
Next question is which side goes into the intercooler ports. The tapered of straight side? The instructions say the tapered side but it will not thread into the manifold and I have seen others that threaded the straight side of the fitting into the intercooler ports. I tried this to but still lots of resistance.
And lastly, some of the mounting hole locations are filled with the gunk used to put the manifold together. How do you get this stuff out? The picture below is the thermostat housing where the M6x30mm bolts goes. I cannot secure the housing because of the this.
