06 T-RED S/C GT
Guys, I desperately need help.. I've tried several times to install the Borla S-type mufflers, however I cannot get them onto the neck of the over the axle pipes no matter how I try to rotate them.. It appears the rear hanger brackets are what's causing the issue, as the brackets for some reason are just not providing enough clearance to be able to slide the neck of the axle backs onto the OTA pipes.. It's almost as though the hanger brackets are too long or something, but I know that Stage 3 motorsports sent the correct part number for my 06 GT.. Borla part #11750..
At any rate, I am totally stumped and don't understand what is causing the fitment and clearance issues, as Borla S types are supposed to be a direct fit for the 05-09 GT models.. I'm also still running the stock exhaust manifolds with stock catted mid pipe with magnaflow tru X welded in place of the original OEM H section along with Magnaflow street axle back exhaust..
Anyhow I'd really appreciate any feedback and advice that can possibly be provided.. Thanks in advance
-Rocky
-Rocky
