07gts197
Im looking for more info and I know some of you guys have done the swap. Most of you guys are probably running the frpp control pack but is it possible to run the stock 3v ecu and coyote ecu in tandum with say the engine connector only on the coyote ecu? And if any of you guys had some pinouts of any 11-16 gt that would be great. I cant seem to find any. Or could a stock ecu be used instead of buying the control pack?
Can a 3v engine harness be used in place of a coyote harness? It looks like in addition to the frpp control pack an engine harness is also needed but it would be easier and cheaper to reuse my stock harness and modify it if needed.
And lastly does anyone know if the harness for the 11-14 dash is that much different than my 07's? Ive wanted to swap to a 10-14 interior too but if its too much work I think Id do a coyote swap first then later on down the road swap in the dash with all needed wiring.
Any info is much appreciated. Ive found some info here and there but I cant seem to find much about the above.
