EBABlacknChrome
Where did you put the 40's at. Before the axle or atfer?
Well we have very similar set ups. Yes, those sound so good with the 40 series as well as the 4.6 4v cobras.
Have you given the Roush Extreme a listen. I am very happy with mine and it will definitely wake up the neighbors. It is different than the Flowmasters.
Mid mount 40 series are the only way to achieve that, a rear mount muffler just can't do it. That's why I still run stock mufflers even with no cats and long tubes, just sounds classic.I am def looking for that old fox body 40 series sound and the roush extreme and outlaws have a more raw/no muffler sound as they are basically a tuned resonator.
The original 40 series is what you want, mid mounted. 1 chamber Flows sound nothing like a 40 series. Run an H pipe, not an X as well.I will never get the exact sound I am looking for but my current setup is very close..it is just not quite loud enough for me.
I have always preferred a louder exhaust and the drone from the flowmasters have never bothered me.
I know the 10's will be closer to the 40 sound versus the outlaws, thats why I ditched those already on Fleabay. There just isnt any louder 40s as the super 40 series are delta flow which quiets em down vs what I am looking for. Even the 10 is a delta flow but it is only 1 chamber so I know it should be louder than the 40.
I will find out Friday as I am doing suspension mods 1st then the exhaust, using the catback pipes from the outlaw system.
Instructions on the rear install are mish mash as they have changed what comes in the kit, spacers/ bushings.. I have the new style bushings (black). The lack of torque specs was annoying and I will be upgrading the hardware next hometime to get proper torque on all bolts. One nut stripped on one of the ubolts so I will be looking for grade 8 u bolts and nuts before next hometime.
I torque EVERYTHING and that ubolt nut should not have stripped !!
I have the newest version of the rear WL sway bar, it doesn't come with any torque specs, how are you deciding what torque values to loose?
The way the bar works doesn't require the hardware to be tightened with a gorilla, I think that's why this bar gets so many mixed reviews. If you are really worried tack weld the brackets in place, any muffler shop can do it for you cheaply. Leave the u-bolt after tack welding it and you're good to go.
With that said mine installed with zero issues, the u-bolts tightened up perfectly and nothing stripped or pulled, again I believe most folks that have this issue are just over tightening the u-bolts.
plain & dry .020 3/8 grade 5 ..31 ft /lb
23 lubed
26 zinc/threadlock
31 plain/dry
The hardware is zinc coated 30 ft-lbs is past the recommended range, but I have a better theory.
I don't believe you can achieve a real torque value against the U-bolt bracket. Since it's not like a main cap against a solid surface, or backed up with a support or sleeve coupled with the having to draw the two sides up I don't think you could ever really get an accurate torque reading.
