Hi,
Well I have a 2005 GT 4.6 3v. Over this winter I did a lot of work to the car that has been neglected over it's years.
New stage 1clutch pressure plate and related parts.
New stainless clutch line
New exhaust. With off road on cat h pipe. With pryes axle back.
Main seal. Pan gasket from time cover seal and gasket.
New time chain, tensioners, guides. (Found plastic parts and pan and got lucky)
Well after all the work and countless hours and months later I get P0012 and another code that says system lean. System lean due to no cat and not tuned yet.
My big issue is the p0012 I know it's retarded timing on bank one. My questions are how far can it be out before I blow the motor? It starts fine just a lopy idle ran fine revs fine.
Second question how do I fix it. My phasers had no mark just two l on them and two LL one them. When I did the new chain I let the cams roll over really easy one way or the other till it stopped then when I was ready to reinstall I used a breaker bar and turn it back till I got the mark to where it was when I took it apart.( I did not rotate only a simple left or right)
The issue I'm worried about is the chain had so much play in it when I took it apart that it worn out the old chain and left groves in the timing cover where the chain slapped around so I'm sure I have the timing off because I don't think it was right. Any help will be nice. What way do I turn the cam to advance it? What's the odds I did more damage then just a took off?
P.s. no tapping or knocking at this time she is the most silent 4.6 I've heard. Minus lope and exhaust.
