Costs for a built motor
JG-1
Hainesport, NJ
How much can I expect to pay a reputable shop to install rods/pistons on a gen 1 coyote?
are you giving them a bare block that doesn't need machining?
JG-1
Hainesport, NJ
No, would be using the block in the car. I understand the job is more than pistons and rods. Just trying to get a ball park of what I’m looking at. I plan on having his done by the end of the year.
Call L&M - they are about a 40 min drive from you. I'd guess you'd be looking at 1500-2000, for machining and balancing and installation.
drive_55_not
I just picked up my new Big Bore Boss 5.0L from TKM Performance in Denton NC,
Pricing would be the same for your 'Yote ..
Machine work, assembling the shortblock , coated bearings , other misc stuff +tax was $2,170
File Fit rings, Assemble Piston Rack, Assemble Short Block, Check Main/Rod Clearance ………………………………………… $600
Balance Rotating Assy/Add Mallory …… $350
Torque Plate Hone 3.702” …………………… $225
Line Hone …………………………………… ………. $225
CNC Deck ……………………………… …………… $200
Polish Crankshaft ……………………………….. $40
Jet Wash/Debur Block …………………. $85
They can also sleeve a 'Yote for $2000.
JG-1
Hainesport, NJ
Will do. They aren’t far away. And that’s actually cheaper than I’ve been thinking. Ill report back what they say.
oh you wanted the shop to pull the motor? that wasn't clear from your post, I know L&M doesn't R&R, only engine builds, your posts talks about rods/piston install, says nothing about pulling the motor and tearing it down.
JG-1
Hainesport, NJ
Sorry, yes, I need the shop to basically do the whole install.
is there an issue with your current motor?
it may make sense then to buy a built short block and have a shop swap it over, either sell the OEM short block or keep it as a spare.
JG-1
Hainesport, NJ
No issues at all yet. I’m pushing a lot of power to the wheels and would like to reinforce the bottom end before something bad happens.
So buy a short block like the Aluminator?
eighty6gt
  • Coyote 5.0L Aluminator Short Block
  • 5:1 Compression Ratio
JG - I think so, you can custom order your CR, the pistons are better IMO, probably better rings and bearings as well. the L&M engine is also blueprinted
Keep in mind if you go to a Aluminator at 9.5CR you'll see a drop in HP all things being equal.
as to the price... maybe a cash discount could be had and you could pick it up to save costs if you have a pick up.
eighty6gt
I would always go with a ford racing engine over a uh... brenspeed, etc...
less bolt turning down the road.
Gabe
Whippled Coyote
