Steering wheel extension?
Craig
Seattle
I'm sure that would work for many folks (especially with a spacer), but I would like to keep the factory airbag.
Fred Rayner
Guelph, Ontario, CANADA
I see this thread stopped in 2014. Did everyone looking for a telescoping solution go out and by a S550? Since there has now been 5 model years of the S550, has anyone tried (or at least contemplated) installing a complete steering column for a S550 (plenty online from auto salvage yards) into a S197 ?
mrt2you
new berlin
why don't you think the other direction.
the steering column bolts to the mount brackets with 4 bolts. maybe make a extension where the steering column shaft bolts to the middle steering shaft, then cut and weld extensions to where the column brackets that bolt to the mount brackets. with the proper extensions welded in place you will move the column up without having to modify any wiring.
i have a extra column in storage to take pics of what i am talking about. the problem is i have to get to work soon. maybe tonight after work i will get pics.
Fred Rayner
I want to make this happen so bad ! I have purchased both a S197 and a S550 complete steering columns from savage yards. I don't know yet if it will be a complete swap or just a component for component swap. My plan is to use the S197 mounts (frame) to moch up a template for mounting and then take it from there. I will start taking some pictures and if it is successful I will post. Wish me luck !!!
Vorshlag-Fair
Official Site Vendor
Official Vendor
Dallas, TX
What in tarnation - that tacked on "steering wheel extension" thing cannot be real. Was that from the Onion? o_O
JDMac34
NE Ohio
Any update on this?
