NITROUS
theRedStorm
I'm looking at a nitrous kit. I'm completely new nitrous. I was told not to exceed 100 shot on a stock motor. I Have FRPP cams if that makes any difference.
What's a good kit? Plate or injected? Any thoughts/tips I should know before heading this route?
I believe it may be not to exceed 100 shot on the stock tune. Anything higher than that needs more fuel and a timing adjustment. But I'm sure you can run more than a 100 shot.
eighty6gt
I want to put a huge jet blasting into my TVS1900 whenever I go WOT! 100 hp... 220, 221.. whatever it takes?
theRedStorm
I do have a custom tune with my JLT intake and FRPP cams. Im assuming my tuner will take care of the nitrous modifications
They should, at least a good tuner can. It will entail a reduction in timing and proper A/F adjustments.
RocketcarX
95% of my weight is fuel
Colorado
Nitrous Outlet's plate kit is the best 3v nitrous system on the market. The ProMax controller would be my choice for running the show.
You'll be fine with those cams, 100 shot is safe for stock internals, but you can go further if you know what you're doing
