Steeda's New S197 Jacking Rails - Now Available (Bolt-in Design)
Status
Not open for further replies.
xeninworx
I want to get these but I’m waiting for them to go on sale from Steeda Canada.
JJ427R
I use the Kenny Brown welded in ones an they are awesome. I have the KB Extreme Matrix Brace welded in as well and that together with the jacking rails makes a huge difference in the stiffness of the car, even though guys on here will say the S197 is stiff enough already and they are only bolt on weight, don't believe it for a minute, the difference is huge and I now just laugh at those guys for not even trying it.
I bought mine from steeda canada, think it was spring of 2018. Think it was aprx $118.00 Works superb.
I do have the steeda X brace still in the box....can't use it in conjunction with my already welded in steeda rear Strut brace in trunk. The X brace goes in the trunk, behind rear seats. 10 lbs, and made from 4130 chromolly steel tubing. (1 3/8" x .082" wall).
xeninworx
The rails now are $289.99. Looking at their IG account, they usually have a sale on Black Friday and Boxing Day.
Racer47
Doesn't have much to say
SE Wis
The difference is all in your head. And the only ones laughing are the guys that are lapping you. You're not fast enough and don't have enough tire to put any real load into the chassis. So you have no basis for comparison. But you'll continue to argue no matter how many facts are presented.
More info from a real racer not just a group 4 poser.
https://motoiq.com/project-budget-400whp-s197-mustang-track-car-intro/2/
This chassis was extremely rigid with a torsional stiffness of 21,000 Nm/degree. This was a substantial improvement over the previous SN95 chassis which was effectively the end result of a 27-year-old chassis and suspension layout design that originated in the 1978 Foxbody Mustang.
By comparison:
4,881 Nm/deg – NA Mazda Miata
7,100 Nm/deg – Honda S2000
9,100 Nm/deg – Chevrolet C5 Corvette
12,500 Nm/deg – BMW E46 Coupe
14,500 Nm/deg – Chevrolet C7 Corvette
22,500 Nm/deg – BMW E90
23,000 Nm/deg – Ferrari 360 Modena
flame away as i know you will.....
JJ427R
There was recently discussion about these on the Kenny Brown Performance Speed Society facebook page and some "real race car drivers" also had things to say on there about them as well as rear grip kit, so feel free to go check that out...
When jj427R jacks up his car, just aft of either front tire..and the entire side lifts off the ground, I call that stiff. The BMR version is actually built better than the KB version. Moot point. Same deal with the BMR version, the entire side lifts off the ground. Without em, one would have to be jacking a helluva lot higher. Whether that increase in torsional rigidity translates into faster lap times with his particular suspension and tire setup is another matter. IIRC racer47 has 400 lb front springs.
jj427R's roush front springs are only 20% stiffer than oem. The roush front struts however, are godawful stiff imo.
GlassTop09
Farmington, NM
Got a set of these Steeda jacking rails installed as well................work very well for jacking up the car.
Hey Pentalab, have you given any more thought into installing that Steeda X-brace?
Nope. Unfortunately the steeda X brace is incompatible with my existing steeda rear STB.
My rear stb is already welded into place. It's either one..or the other. The X brace still sits in it's box. The X brace is a superbly built piece of kit. I will get around to listing it for sale..soon.
Right now we are gagging on smoke outside, 24/7. Fine ash on everything. Screwed up part of my front deck paint job.
Status
