Bump stops
C5illini
Illinois
I am installing steeda springs and shocks/struts,they recommend cutting the bump stops down,if I use the softer gt 500 stops do l need to cut them down? Thanks. Rod the car is a 2006 gt conv
EBABlacknChrome
Michigan
If its lowering your car then yes. Softer still will not change how fast they contact the car/less travel. Bump stop relocation brackets would allow to to keep them full length if I remember correctly. I don't recall the brand that @Adrewnagle used but they are pretty simple little plates.
Norm Peterson
corner barstool sitter
RIP - You will be missed
Softer will change how hard it feels when the car hits them.
If you're going to cut the stock bump stops down, it's probably best if you start by cutting only a little. You can always cut more off if you feel that you need to, but you can't put it back on if you cut more off than you had to. Bump stops perform a useful function, so it's best to keep as much of that usefulness as you can.
There are DIY ways of putting some of the softness lost by cutting the soft end of the bump stop off, back in.
AndrewNagle
Mountains of NC
I’ll have to look and see what I can find or remember but you are right they were simple
Can,t remember if these were it but same concept
https://www.revanracing.com/products/bump-stop-relocation-brackets.html
C5illini
Illinois
So you should cut down the softer bump (gt500)stops also? I do not have wheel issues,running gt500 wheels and tires. Thanks
Vorshlag-Fair
Official Site Vendor
Dallas, TX
When you lower an S197 by 1-1/2" or so, we like to cut the axle-mounted bump stop in half...
We found this out after just cutting the top nub off and it was still smacking the bump stops...
Again, 1-1/2" to 2" lower than stock you're gonna need more room than that. We have installed real dampers dozens and dozens of S197s first hand.
Also, some aftermarket rear shocks (from properly designed coilover kits) are shorter than stock and often have bump stops added in-line on the shock shafts. In that case you can remove the axle-mounted bump stops completely. MCS and Moton tend to not use shock-mounted bump stops, however.
Good luck,
