Accelerometer on Track Apps Cluster.
LarryJM
Resident Fuktard
It says there is no difference between E15/88 for $3 a gallon and BP/93 at $4 a gallon both at 75 degrees inlet temps. Picture of BP93 alcohol test. There is a big difference with inlet temps at 70 degrees and 100 degrees with both gas mixes what ever they may be.
Norm Peterson
corner barstool sitter
RIP - You will be missed
Wrong thread???
LarryJM
Resident Fuktard
Wrong thread???
Well it seems it gets to the right thread sooner then later. In the early morning I get air intake readings of 70 degrees when it's 70 degrees outside. It's near 100 when it's 95 outside. Big difference in g forces between these two temp. Much more then gas quality.
LarryJM
Resident Fuktard
Most likely tire temperatures that I suppose would be at least somewhat consistent with the temperatures you're able to log.
Track Apps does not give tire temps or pressures. Although there might be a secret code to do that. There is a list on line about Ford secret codes. For sure I get air intake temps and outside air temps. They usually match for the first 20 minutes or so. When the temps get close to 95, the air intake is about 105. G force is down at least 20%. I am not sure a CAI system would be much different on air temps unless it's hooked to the air conditioner.
