broken manifold rear bolt
whitmanink
denver pa
hey guys ,
just started to break down and tear apart my 3v ,,
days prior , i sprayed the rear manifold bolt nuts with PB blaster,,,
lastnight i had a go at it,, and the results were good,, heat and an impact seemed to do well,,
well the 3rd nut seized onto the bolt and snaped it off,, theres about 2 inchs of bolt hanging out, so when i pull the heads off to do the head gaskets, ill heat and screw that broken bolt out,,,
but i cant seen to find a replacement bolt to fix this manifold,, i can find the manifold bolts that bolt the exhaust to the head,, but cannot find the rear 2 bolts that screw the manifold to the exhaust??? thats what i need as i snapped one,,
all my searches come up with the bolts for the manifold to head???
anyone know where to get this replacement?
Iceman62
Bullitt 6005
NE
@skwerl has you covered. Pretty common issue, when working on semi-older motors. Now you'll have fresh anchors f/ the project. :D
These are labeled as 62mm long. They also list some for fords that are 72mm long, but the longer ones interfere with installing the oxygen sensors. I just went through this replacing a cracked exhaust manifold on my 5.4 in my F350.
