Miss at idle on 2010 4.6 3valve motor
Speedracer67
Had a check engine light and miss. Checked code and it was misfire on cylinder #2.
182,000 miles.
Changed all plugs, with no problems and #2 coil pak.
Now have a miss at idle, clears up above about 1000 RPM.
No check engine light, engine runs good on the road.
Any ideas??
TIA
Rick
Dino Dino Bambino
I have a red car
Cyprus
You might still have a pending code so it might appear if you wait long enough.
Did you apply nickel anti-seize to the barrel of the plugs where they meet the head (not the threads)? It's possible you might have accidentally contaminated one of the electrodes.
Speedracer67
Motorcraft plugs, didn't need gaping. Don't think I got lube on tip of plug.
Do have original injectors but I was hoping to get a code.
Will post what I find out
Thanks
Laga
Chicago
I’ve had a brand new Motorcraft plug go bad after a week. Never threw a code but wasn’t firing. You might have a bad one.
Speedracer67
What brand plugs do you think might be better?
I hate to pull all 8 plugs to see which one might be bad.
Dino Dino Bambino
I have a red car
Cyprus
After 100 miles of driving you'll either get another code or, if it's just a fouled up plug, it'll clear up.
You already have the best plugs for your application. Luckily yours is a 2010 model so you don't have to worry about breaking any plugs upon removal, so it might be worth your while doing so to find out if any of them looks different from the others.
Speedracer67
No I didn't. Gap looked the same on each plug. How would you change it? Bend the loop on the bottom?
If you have the stirrup style strap on your plugs there is a tool you can get for gapping. I use a different style plug but when I ran HT0s I would take them down to my local modular garage and tell them what gap I wanted and tossed the guy a double sawbuck.
On my 2010 GT, the oem gap is 1.5mm / .060". Since I have a small roush M90 blower, the gap is reduced to just .035" (5.7 psi boost). I replaced the plugs years ago, with Brisk silver plugs, and gapped to .035". If no blower involved, the gap is set to .060" / 1.5mm.
Dunno what the gap is on plugs...right out of the box. They all looked identical, but were not .060".
I've been running my blower for so long I don't remember the stock plug gap but that seems awfully big. I can't imagine it being much bigger than .045 or so.
Manual sez .060" or 1.5mm. Blower went in just a few months after I bought the car, so it's been .035" ever since.
Sammy70
Any ideas??
TIA
Rick
Unplug injectors one at time while engine is idling and listen for a change in rpm.
If one cylinder has no change you'll know the problem cylinder and can go on to check each component--plug, coil, injector, etc.
I've changed literally hundreds of 3v spark plugs and have seen the occasional dead plug right out of the box.
Speedracer67
Sounds like a good plan. Still no check engine light but miss is still there.
Will report back.
Thanks
My 5.4 3v has a tap at idle that instantly clears up with a little throttle and runs awesome. My mechanic said it was the phaser not getting enough oil at idle. I already upgraded my oil pump so the next step is thicker oil.
