richie9mt
...So I decided to fix it...
I took off the throttle body and cleaned the sludge off with Throttle Body Cleaner, cleaned the MAF sensor with MAF sensor cleaner, and took off the accelerator pedal and checked/wiped off the attenuator contacts.
Put everything back together, and got these error codes...and it's in limp-home mode now...
P1000-FF; P2104-FF; P2123-FF; P2129-FF; P2132-FF; P2104-C
I've read that three of these are module codes and the other three are throttle body and pedal DTC's...
Nothing was replaced, nothing looked bad. Car ran fine until I just had to clean some of the parts that were suggested in other threads (88,000 miles). The TB position sensor is the old style round type, which from threads I've read here is failure-prone.
I'm using ForScan to read my codes, but even though there shouldn't be anything wrong with the TB/pedal (other than being clean), I can't delete the codes.
So...besides being stupid, is there anything I've done that should have bricked the car???
Thanks for any comments!
