Technical problem with key remote
WJBertrand
Has anyone experienced a problem where the remote unlock and trunk open key buttons would not work? I had to open my door with the mechanical key after parking for about 2 hours, driving a short distance then parking again. It has worked normally again after that. I must have pressed it 10 times standing right beside the car - nothing.
I have a 2013 GT. I don’t think the remote battery is dead since it worked fine later.
Has anyone experienced a problem where the remote unlock and trunk open key buttons would not work? I had to open my door with the mechanical key after parking for about 2 hours, driving a short distance then parking again. It has worked normally again after that. I must have pressed it 10 times standing right beside the car - nothing. It is quite easy to program and you only need one working key.
I think the buttons get worn out. My key still has good batteries but will not unlock my car. I got one of these and use it instead. It is easy to program too.
https://www.amazon.com/gp/product/B073W8MTB9/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&th=1
86GT351
Sunny South Florida
Common issue. The buttons get worn out. You can open it up and make sure there is no corrosion developing inside also.
WJBertrand
Thanks for the answers. It’s strange because I switched from using an aftermarket key (long story) back to a spare factory key so it has only been used for a month or so. I wouldn’t expect the battery to be dead, though it is original still. Also, it continues to work fine since that occurrence.
jonathan sanders
atlanta
Has anyone experienced a problem 192.168.100.1 192.168.1.1 where the remote unlock and trunk open key buttons would not work? I had to open my door with the mechanical key after parking for about 2 hours, driving a short distance then parking again. It has worked normally again after that. I must have pressed it 10 times standing right beside the car - nothing.
do you have some recent fuse problems ?
WJBertrand
Thanks for the reply. No fuse problems recently or ever in fact. The remote is still working fine since my post with no recurrence. Weird.
