Driveshaft balancing the Ford way?
Miker
USA
For me an impact wasn't going to do it. The angle is wrong and there was too much movement of the driveshaft which cushioned the impacts. I think I only got one loose with it and that was after heat and PB Blaster. For me what worked was having the car in first gear and using a long breaker bar setup so I could push on it with my foot. This worked.
I did mine on jack stands. If I had the car on a lift I am sure I could have used my arms but on the ground there wasn't enough room to get the leverage.
In the end I broke a 12 point socket and the bolts were mangled up enough that I bought a new set for the install.
JC SSP
FL
Just the surrounding area…. A little heat goes a long way. Not on the bolt but on the steel flange area. If you’re concerned wrap a wet rag around the pinion bearing area of the differential housing.
JC SSP
FL
Go with the proper socket and extend bar (leverage is your friend). Also try another high powered impact gun. If that doesn’t work a little heat.
GriffX
Rural Germany
It looks always so easy on youtube.... Not sure if my breaker bar fits straight on it, I have an eazycarlift, so I'm on my back. Thanks for the hint with new bolts, pretty sure Ford Germany will not have them. They even do not have a plastic clip for the fender.
Miker
USA
My local Napa had a set of the bolts. Also I was able to reach over the tail shaft from under the car and move the shifter linkage from 1st to neutral and back. Made a huge difference not needing to climb out from under the car for each bolt when torqueing them down for my aging body.
GriffX
Rural Germany
Rural Germany, all Hardware stores gone with not the wind but the lockdown.....
My breaker bar fits not good, but I can reach them. Will do it tomorrow, it's 8:30 pm here.
For your ageing body I have the appropriate video for you ;)
PS: Bolt No
N800594-S101
is also used on the S550, so my Ford dealer will have it (for the 10fold price I guess)
A 6 point socket is a lot stronger.... and the only thing that should be used on any impact wrench. Oops, just see u have 12 point bolts, wtf?
Miker
USA
I think they made them 12 point bolts because there is such a limited access angle to them. I think I used a 2 foot 1/2 breaker bar, a 1/2 to 3/8 adapter, a 3/8 wobbly, and a short 12 point 12mm socket.
And yes I too was taught to use only 6 point sockets with an impact and preferably an impact socket. I did break 1 12 point with the impact trying to remove them.
GriffX
Rural Germany
They are 12.9 grade steel 12pt bolts M12 at the transmission flange and should be torqued with 103 Nm. I think with a 6 point bolt you would not be able to put a socket on it.
GriffX
Rural Germany
Got it out, with 2ft breaker bar, workshop drowned them in green glue. Penetration oil stopped right at the glue, so useless.
PS: Cleaning the threads will take some time :(
GriffX
Rural Germany
Question: I'm a very unexperienced "welder", if you do a spot weld at the edge of two sheets like here, to find the weld parameters, do I have to add the thickness of both sheets? Let's say one has 1 mm, so I go to the 2 mm thickness values in the table for the MIG welder?
Thanks!
GriffX
Rural Germany
Did it. To install the modified driveshaft under my car I needed 2h with cleaning all of the threads from the glue and so on (used blue Loctite now). Longest part was to get the two bolts at the carrier bracket in again. I measured the U-joint angle at the transmission to 2.6 deg. All in all I needed 3 evenings.
I also found this yesterday:
DieHarder
Looks like the best/easiest method to fix the problem and doesn't require removal of the driveshaft to boot. Not cheap but avoiding all the hassle is worth it (at least in my opinion). :snoopy
GriffX
Rural Germany
Yes, expensive but this method I did is really not recommended for doing it in a driveway. I have seen this product too late and I have an other option now if my work doesn't lead to success.
One Caveat for people who want to change it, I have seen that you can twist the bracket when you torque the bolts to spec and the bracket is not perpendicular to the shaft anymore afterwards.
DieHarder
I went ahead and ordered one since I'm sure mine is overdue (18 yrs on original carrier bearing and ~130K). I'll take some pics when it gets here but they indicated on the order they're not shipping until April. Must be manufacturing these in batches or supply chains are still slow for some parts.
GriffX
Rural Germany
In their install video they cut the bracket in half, the 4 tack welds on top are very easy to grind of instead, no need for the big 'uns.
Are you folks taking abt that bearing, where the oem 2 piece DS joins in the middle ?
GlassTop09
Farmington, NM
Thanks for posting this...................have also ordered 1 myself w\ both sets of durometer inserts to see which set I'll like installed.
FYI..............I contacted JXBPerformance as to why w\ the 10-14 S197's you reuse the OEM spacers but w\ the 05-09 S197's you don't........was informed that their carrier assembly is designed to the 10-14 S197 carrier housing dimensions (makes this approx 1\2" taller bearing center-to-flange than the 05-09 housing) thus w\ the 05-09 S197's the OEM spacers aren't needed to return driveshaft to correct alignment.
Didn't know that the DS center carrier housings were not identical dimension-wise between 1st Gen vs 2nd Gen S197..........good info to know.
GriffX
Rural Germany
To be precise more about the rubber around the bearing holding the driveshaft in place. Mine was lying around like a cooked noodle and had some bad vibes from 65-70. Hope they are gone now .....
