Hi, I have a weird issue after installing my supercharger. i am waiting for a response from Kenne Bell, I feel like there is a tune issue, but I am setting a code for the Cylinder Head Temp sensor, P1290. The sensor what new because I broke the original, I then pull off the SC and intake and put a new sensor in from Ford. The first new sensor did not show a temp on the data stream. The new one does but I still set a code. What is stranger is the temp gauge. If the engine is not running the gauge works and gives a reading. When the engine is started the gauge rises then falls. I don't have any other issues, no other codes or anything else acting strange. I did not have this problem before the install, I have check the wiring. I would do more checking but since the temp gauge gets its setting from the CHT and it works when the engine isn't running I feel like there is a tune issue. I am curious if anyone else has seen something like this?
Here is a link to a video of the issue.
