Allan Hastings
- Joined
- Nov 28, 2018
- Posts
- 14
- Reaction score
- 1
The overhead dome/map light on my 2011 GT comes on as it should when the door is opened or unlocked with the key fob. Problem is, it won't turn itself off when the car is running and underway, even if I try to do it manually. This is a problem after dark, driving the car with the light constantly on. I could remove the bulbs and lose the map light, but now and then that function is needed. All standard operator actions that result in the lights coming on work as designed. The lights eventually go out but only after a long time, just as they would if one door was left ajar or open long after exiting the car.
I believe that the signal the engine sends to a logic circuit somewhere in the electrical system is not being received that would otherwise result in a power interruption to those lights.
Any ideas about where to look for a failed component?
