Bigearl
2007 Mustang engine with 75k miles was stored for 8 years and recently disassembled and found to be in generally good condition. It was then rebuilt with new Ford parts in timing chain assembly, rockers and lifters, con rod bearings. piston rings and gaskets. The timing cover was carefully replaced with new gaskets and the use of "Right Stuff" at the cylinder head to block joints, at the cam cover joints and at the oil pan.
This engine is installed in a Factory Five Cobra replica with Ron Francis electronics that allows it run with just the original ECM.
The engine started up straightaway sounds good and no error code issues diagnosed. We have run the motor at idle and driven the car a short distance without the body on, there are no oil leaks until we shut the motor down. Then we get about a half teaspoon of oil from each side of the timing cover leaking from the outside head to block joint area, no leaks from the inner sides of the V. We have verified there is no pressure in the crankcase causing this as we have removed the oil filler cap at the time of shut down and also the vent from the PS cam cover is not blocked.
I am aware that some boosted engines have issues forcing oil from the timing cover but this seem like oil just draining and then leaking on shut down so I am puzzled.
Any thoughts, advice or similar experience would be appreciated. Earl
