Dustin Hunt
My third brake light works but others two don't tail lights turn signals hazards everything else work fuse is good brake light should be good if third brake light works replaced turn signal switch but still nothing
What year? GT or Base? Most likely the brake light switch.My third brake light works but others two don't tail lights turn signals hazards everything else work fuse is good brake light should be good if third brake light works replaced turn signal switch but still nothing
Not always. 3rd brake light has a separate circuit wireThe third brake light works so the switch is working.
Look at the above wiring diagram that was posted by another member. Verify power on all wires coming off switch. The brake Lights and the 3rd brake light have separate wiring.It's a 2006 gt there is power at the brake light fuse and power at the brake light switch even if I jump the switch only the third brake light works
Connector is 2280 and the pins 14, 18,..... cable color WH-RD is white-red and so onSorry I suck at explaining what is that diagram of is it a plug on the sjb if so which one etc
Diagnosis or Paperwork supplier?Jeff what's your hourly rate for electrical diagnostic? LOL![]()
LOL! Sadly no alcohol for me since my diagnosis. I have become a cheap date. Water with Lemon or Unsweetened Tea with Lemon. Add a little sweet and Low and I am good.Could be cold beer or bottle single malt?
