No brake lights
Dustin Hunt
Sanger ca
My third brake light works but others two don't tail lights turn signals hazards everything else work fuse is good brake light should be good if third brake light works replaced turn signal switch but still nothing
86GT351
Sunny South Florida
What year? GT or Base? Most likely the brake light switch.
Dustin Hunt
Sanger ca
It's a 2006 gt there is power at the brake light fuse and power at the brake light switch even if I jump the switch only the third brake light works
86GT351
Sunny South Florida
Look at the above wiring diagram that was posted by another member. Verify power on all wires coming off switch. The brake Lights and the 3rd brake light have separate wiring.
Dustin Hunt
Sanger ca
I'll have to check when I get off work today is that the plug on the outside of the sjb that you can see same side as the fuses
JC SSP
FL
Jeff what's your hourly rate for electrical diagnostic? LOL ;)
JC SSP
FL
Understood but thanks for always helping out.
