Early S197 Coyote swap.
Mbara80626
LongIsland NY
Hello Everybody!!
I'm new to the world of Coyote and S197's so some info would be appreciated I have a 09 Mustang GT with a 3V and have the opportunity to pickup a Gen 1 Coyote. I'm not looking to build a monster just a daily driver. The info I received about the engine is its out of a 2011 mustang and it had a misfire issue.. What are the know issues with the Gen 1's.
Thanks
Dino Dino Bambino
I have a red car
Cyprus
You'll find a lot of helpful information about Coyote swaps on this page:
I'd also recommend you look up our resident Coyote swap guru Matt Soppa on YouTube. He has an excellent series of videos describing a Coyote swap into an 05-09 GT.
As for the misfire the most likely causes are either a bad spark plug, COP, or injector. Before buying any engine with an unknown history, a compression check on all cylinders is crucial as this will determine the general health of the engine. Otherwise there could be a mechanical cause of a cylinder misfire such as a bent/burnt valve, a broken cam follower, or a damaged piston that you'd miss if you didn't perform a compression check.
If a compression check isn't possible, pull the plugs and examine the cylinders with a borescope. The no.8 cylinder on early Coyote engines has a tendency to run hotter than the others, and some would develop premature exhaust valve guide wear or detonation on that cylinder.
Generally Coyote engines are robust and reliable but like any engine, a timing job will be required at some point depending on how the car it came from was driven. Buying any used engine is a gamble but an inspection under the valve cover, and a check of the oil colour/quality on the dipstick will give you a clue as to whether the engine was properly maintained.
Mbara80626
LongIsland NY
Hey Everyone. Question. The Gen1 engine stated above fell thru and I was able to get my hands on a gen 2 engine from a f150. What needs to be changed to use the Gen 1 ecu? Phasers, Cams ,Exc? Thanks in advance for any help.
mattjames
Just the gen one cams and phasers
konablue11gt
Evansville IN
On gen one ecu you do mean a gen 1 coyote ecu correct?
Mbara80626
LongIsland NY
One more question on transmissions. I want to use a 6R80. I know use a MT!! Lol. I have a bad left knee. So anyway does it matter if I use a gen1 or gen 2 6R80 ? As usual any help is appreciated.
mattjames
Yes. Need to use a gen1 6r80 with a gen one ECU unless you change the valve body in the 15-17 6R, but don’t quote me on that. I’d just get the 11-14 6R
lwarrior1016
mississippi
You can use a gen 2 6r, but it won’t shift perfectly. It can be tuned to shift correctly but most tuners won’t deal with that. You can swap a 13-14 gen 1 valve body on to the gen 2 transmission. That will allow you to update the solenoid strategy correctly so the transmission has the right baseline to start with.
Mbara80626
LongIsland NY
I have a question on Ecu's. Which are the preferred ecu's 11-12 or 13-14?
Thanks in advance for your help..
mattjames
Depends on if you want select shift or not, if so then you need 13-14 ECU, but the you need the newer 13-14 cruise buttons/wheel for cruise to work.
If you don't want select shift, then 11-12 will work and the cruise will work with the 05-09 cruise buttons.
