*Video* odd noise from rear end
Joek
Leesburg Florida
Im gonna try to make this short and sweet.
I bought the car about a month or two ago.
I have this whirring noise from the rear end over 20mph.
I just replaced both wheel bearings, fluid and diff cover. Still have the noise
Is this normal?? You can hear it in this video when i get off the throttle.
I never noticed it and then put the seats down to put golf clubs in the trunk, and it is LOUD with them down. Pinion bearing seems tight.
Thanks
Joe
86GT351
Sunny South Florida
Pinion Bearing feeling tight does not in any way tell you if there is a bearing issue. Pinion preload could be off. Backlash could be off. You are going to need to have a further inspection done to see the inside of the differential. How many miles? The seat cushions actually work as a sound deadener. The other thing to look into is the upper control arm. Bushing might be collapsed causing the noise to be amplified.
Joek
Leesburg Florida
Its got 79,000 miles on it. The car is all stock other than the mufflers. I would find it surprising if there was an issue with the diff at this milage but i can take it in
Thanks for the reply
86GT351
Sunny South Florida
It is very possible.
GriffX
Rural Germany
In the end it doesn't matter if it is the pinion or carrier bearing, I guess you have won an overhaul. My pinion bearing was gone at 25.000 miles (but it was the old style weak one).
Joek
Leesburg Florida
Thanks for the input, what year is your car? Curious if mine is the old style. My breather is on the passenger tube.
GriffX
Rural Germany
07 so you should have the new one already. If you don't change the gears or diff, just to change the bearings is not too difficult, just time consuming. And you need some tools.
