Warning beep under panic braking?
Miker
USA
Took the car for a quick cruise tonight. Came over a slight rise at about 40 and a deer ran across the road in front of me. Got on the brakes hard and didn't hit it thank you very much. But there was a single beep like the beep you get when the blinker is on too long. Less than a second in duration. Is it related to the anti lock brakes? Is it normal or should I be concerned?
Autokyrios
VA, USA
Beep or a tone? I'm not aware of any signal that makes a beep sound, except the horn. Tone, like the seatbelt warning sound, sometimes comes with certain alerts. Also could just be the universe in the oh-sh!t moment.
Wouldn't worry too much about it unless it happens again.
Racer47
Doesn't have much to say
SE Wis
low on brake fluid warning? idk just a guess
Miker
USA
Tone I guess. Not the horn but the warning sound like when you leave the blinker on too long.
That's the first thing that came to me too. It isn't low.
BullittSS
New Braunfels, Texas
This is from the 2014 owner manual, mentioning a noise from the system, that is normal. You may want to check your manual, in the Anti-Lock Brakes section.
"HINTS ON DRIVING WITH ANTI-LOCK BRAKES When the system is operating, the brake pedal will pulse and may travel further. Maintain pressure on the brake pedal. You may also hear a noise from the system. This is normal."
86GT351
Sunny South Florida
The sound they're referring to is the ABS unit chattering. I don't believe there's any signal tone for it.
This would be my guess also. Not a beep. Under "Panic" stops the ABS can feel like it is chattering when applied. It is normal and is doing it's job!
Racer45
BC
So sometimes when I’m racing my 07 GT and I’m bracing my self to take a hard corner and or braking hard sometimes my knee will slightly lift the hand brake for a moment that could set off a chime. I suspect this is my best guess of what you experienced last night. You can confirm this next time you head out for a rip try pulling up you handbrake slightly and see if that’s what you heard
Ive never had a abs chime in my car. And I work that system pretty hard and often
Miker
USA
I think this is exactly what happened.
crjackson
Midgard
Same here, also at one point, I thought my cruise control was malfunctioning on road trips. It would randomly stop holding my speed.
When I would go over a rough section of road, or shift my body for any number of reasons, I was pushing my knee into the handbrake and causing it to shut off the cruise control.
I didn’t hear the chime (I’m hearing impaired) for a long time, but my wife did, and that’s how I figured it out.
Autokyrios
VA, USA
Check your p-brake switch to see if it's gummed up (not rising fast enough to take up the slack). You can also tighten up the lever. It's riveted but you can still bend it a bit to help, or drill out the rivets and put in bolts with nylon washers.
MrBhp
I've had my low fuel chime ding once under heavy braking if the tank was getting close to low.
