How to Install a 2010-2014 Mustang Steering Wheel into a 2005-2009 Mustang
cjust2006
Houston, TX
Smaller update: Yeah. It's definitely those two wires. Testing resistance across those two while pressing buttons triggers differing resistance. That Dynavin 4-pin plug for SWC only has two wires. Unless there is something that one of the other non used wire terminals can do, a PAC is the only way forward.
drh1701
Kent, WA
Good stuff! Personally I prefer the one made by akdoggie since I helped him with it but this one is really good as well. Good job.
FYI You don't need a PAC adapter, even if one installs an aftermarket radio.
I do like that you have info about the Dynavin units.
Did all this like 2 years ago (the Dynavin) and had a 2010 steering wheel installed for 9 years now in my 05-09. This will surely help others.
Do you have a link to that guide?
08-GTCS
USA
Can't wait to do this mod. Dude THANK YOU for this, I've had it saved for a year now and haven't got around to it yet but can't wait
Ceskz
Italy
Really precise and awesome guide..I'll be soon switching my stock steering wheel with a 2011 gt500 one thanks to that....just one question about the radio control buttons.. currently I've got an Android aftermarket radio mounted..and it have proper wires to connect to the steering wheel buttons(universal stuff)..is still a PAC required ,or not?
VGMStudios
Canada
Depends on the radio. PAC is not usually required if you follow the guide I posted. I run a Dynavin and you don't need a PAC unit for the buttons.
Awad Alibrahim
Saudi Arabia
Hello everyone! I decided to create an in-depth tutorial on how to create the wiring harness and install a 2010-2014 Mustang steering wheel with audio controls into an 2005-2009 Mustang! I know there's been a couple tutorials out there, but this one is supposed to be the "end-all" beginner/advanced tutorial for any level of experience! This ALSO INCLUDES a tutorial for the newer Dynavin radios, such as the N7 Pro or N8 Pro (which I personally have myself.) Thanks guys, and if the link dies or something happens, let me know! I should be able to refresh the link soon after!! :)
https://drive.google.com/file/d/1a-pYGuLFhT1mZ_OeV3itvsuV9duPDeI9/view?usp=sharing
Good luck!!
I know it's been a while since the release of this guide but I have a question
Where does the pink ground eyelet go exactly? (after soldering it to pin 7 and 4) Is it there from factory on the 2010+ wheels or is it an addition?1001712667.jpg
SmokeOps
I have one question. I recently bought a complete 2013 Boss 302 steering wheel, except for the airbag, that came with the Track app buttons. Does anyone know if I can just buy the 10-12 buttons Part #AR3Z9C888BA and put them in and use the wiring harness from the steering wheel, or would I have to buy a harness from a 10-12 steering wheel?
