road racing s197 porn
KIMMER
Admin
What we will do is break track discussion & timeslips into a couple subgroups under that forum. One specific to drag racing, and one to road racing. The primary track discussion & timeslips can be for just posting times.:thumb:
ZmanM3
The Evil One
Jackson, NJ
Sweet!:thumb:
DusterRT
Defected to Deutsche
Seattle, the Sunshine City
What master cylinder do you run? Reading that article it doesn't address it so I assumed a GT M/C would be sufficient but now that I've installed my GT500 brakes, I can put the pedal to the firewall without an excessive amount of effort. I've bled the front circuit twice after installation and then a third time when I did all four corners yesterday so I'm pretty confident there's no air in the system..
GT_350
More Brake Tech
Thanks for the info...and the info in that link should be a sticky (if we had more corner carvers here..)!
Looks like for street use the GT500 setup will work well enough but won't utilize the full braking capability. For my use however I think I'll eventually want to step up to the GT500 HCU and ABS computer. Now I just gotta find someone who wrecked theirs...
FYI on the GT500 ECU/HCU swap in a GT I've been told you will lose you Traction Control.
I've got the same "soft" pedal, talked to Ford and they said that was normal with the GT500 stuff on the GT. They seemed to be more concerned about the brakes being feeling a bit grabby than having a soft pedal.
I got four track days on the car with the GT500 brakes and FR500S ECU/HUC and although the pedal feels soft, I have not run out of brakes running the 3.7 course at Sebring. I can really brake latter when going into a turn but I have to get braver and carry more speed into those turns!
I guess the Master Cylinder on the GT just may be at near its limit when installing a larger caliper. The larger caliper requires more fluid volume, more fluid volume equals longer pedal travel, so that means less fluid in reserve and that equals the soft feel of the brakes.
Next week I'm going to have the GT500 Master Cylinder and Brake Booster installed.
I'll stop by after the install and let you know if there is an improvement.
Here's more on the brakes in a different tread.
DusterRT
I took my car into the dealer this morning to bleed and cycle the GT500 ABS unit I swapped in. They bled it OK but they were getting codes for the traction control (expected) but they were also saying "things aren't communicating properly" so they spent an additional 120 of my dollars trying to figure it out (no dice). They seemed unclear if it was just the TC affected or ABS as well. Any input on this?? I've got a track day coming up next week but don't want to take it out in an unsafe/unstable condition..
Edit: Looks like the only thing affected from the HCU/Module swap was traction control. The TC button is in a constant state of "OFF" now and the light is on in the cluster. It does throw a code (I forget which one), but it is TC related only, not ABS. So should anyone else happen to have this happen, don't have your dealer waste any time trying to fix TC related issues; that effectively doubled the cost of what should have been a simple $130 brake bleed/HCU purge...
ZmanM3
The Evil One
Jackson, NJ
My TC is turned off in the tune. Its better and safer that way. If the TC is turned off in the tune though I don't think should be throwing any codes.
STEVE_POE
coyote powered fr500s
Cincinnati
any updates on the s197 road racer??
update: things have been crazy as of late but I finally got around to getting a couple pictures. it's getting panels hung and should have paint on it by the middle of July . going to hit a track test day in 1st. week of August. was put on scales like you see it at 2,380 lbs.no driver 3 gallons of gas. a few pics. yes, those are 17" wheels with 14" brakes sitting under them.
STEVE_POE
Cincinnati
hood and fenders are on. had to weld and drill all the hoods pins. as for the hood vent it's a work in progress. new wheels and tires are on as well.
STEVE_POE
Cincinnati
got a body on it now. complete the car now weighs 2,650 lbs with about 3 gallons of gas. starting to prep for paint
fhlh
Grabber? Don't Know Her!
Houston
yeah... that's cool and all.. but what will it run in the 1/4????
:thud:
j/k... I could only wish to get my car setup for some serious road racing!
Are the new wheels 18's? What are they?
STEVE_POE
Cincinnati
Thanks guys more pics soon.
who cares what it runs in the 1/4. lol it will never see a drag strip.
