My S197 Project build thread
Matt D
S197 Pilot
Toronto,Canada
I also put the moroso Drive shaft loop in, the way they want you to install it is to remove the x or h pipe so the hangers are out of the way and it slides around the rubber bushing. Since I didn't like that Idea I cut around it so it clears with the hangers on. :)
08VistablueGT
Booyakasha!
Reston, VA
Some of you wanted to see the plastic ported intake I have, kind of crappy pics but heres some quick shots. I also painted it and added my little touch on the top with a shop sticker :p
Also just test fitting the bling bling t-body!
Car goes on the dyno today to see the differnce with the ported intake, throttle body testing will be tomorrow.
If I gained 5hp at the wheels id be more then happy lol :clap:
enjoy :beerchug2:
Looks amazing!
Matt D
S197 Pilot
Toronto,Canada
My next few things to do will be getting Qa1 coil overs for the front and adjustable rear shocks
THEBLUEBOMBER
Washington DC
Matt, do you power shift ever gear? Have you tried launching lower then 6000 rpms? You have to be spinning. I bet if you change out the springs, put on the anti roll bar that you have, and launch at 5k rpms instead of 6k you'll be in the 11s easy.
Matt D
S197 Pilot
Toronto,Canada
Im not spinning at all I wont launch it under 6000, once I change the suspension it will only help me more to get into the 1.5 sixty foots
I got a 1.60 sixty foot best with sportline springs lol
I bang every gear hard lol watch my videos
lostsoul
2014 vett or 2015 stang..
Gay Area
The best 60 was 2.0 :-/ that with 500wrhp. Ahhhhhhh someone show me how to drive !
Matt D
S197 Pilot
Toronto,Canada
I havnt updated this thread is mad time, so of course the frpp intake manifold on it.
I just did the qa1 coil over front last night with the caster camber plates and the rear race shocks. They arn't the greatest pics but meh...
knocked off 14lbs off the front
(the caster camber goes inder the tower like oem style)
If you plan on buying the coil overs make sure you buy the $20 adjusting tool it makes it alot easier!
matt texass
For the QA1 caster camber plates- is there any kind of grinding or rigging that needs to happen to make them fit like the new edges?
alloy6ix
Wiener Dog Racer
Big ass state shaped like Texas
Is that Scale accurate? Has it been calibrated before and after the DaSilva racing sticker? has the DaSilva Racing sticker been weighed separately? has the adhesive on the sticker been weighed? has it been weighed at gross weight with the protective backing around the adhesive for research purposes?
:thud:
j/k man, good luck getting that thing to a 11.99 or better. :beer:
